Pick Path Sweeps NEVER Work
3 ANTWORTEN 3
Nachricht 1 von 4
391 Aufrufe, 3 Antworten
They should just delete the pick path tool for sweeps because it will always tell you there's a circular chain of references and never work. Also they should delete the pointless profile lines that you automatically go to after sketching the path, and make it so you automatically go to the profile sketch.
3 ANTWORTEN 3
Nachricht 2 von 4
bin
als Antwort auf: Anonymous
Did you create a sweep that affect the path?
For example, you create a sweep and join it to the host element, or create a sweep void to cut the host?
Not sure what the second issue is.
Nachricht 3 von 4
Pick Path is necessary should the sweep is not on a single plane. Maybe show what you are doing and find a solution rather than dismiss the tool.
Nachricht 4 von 4
Are you kidding, venting or both?  It is possible that the sweep tool is wrong tool to use for the task.  Can you post the file?
