When I try replacing Physical or Thermal assets on a material, some categories do not have any assets to assign. In the example below trying to change the Physical assets of a material to carpet. Any if I try to add thermal assets, there are none available. As shown below, there are only 2 physical assets available in the entirety of Flooring and none under carpet. Is there a library that must be loaded to obtain these assets.
Gelöst! Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
Why don't you just use a generic or populate the values of an existing one to match Manufacturer Specs?
Didn't notice there was a Generic to choose from. I guess I'll just choose the generic unless I have very specific information on thermal or physical properties. Thanks.
Actually, there isn't a "Generic" Carpet. It's just called "Carpet". Just use that one or any like Physical/Material Asset and input the values you want.
