Photo Image Mapping to surfaces
Hi All, after some advice or tricks that might be out in the community. I have a series of photos taken of existing buildings. I have a model that has been provided by council that is basic geometry of the subject site and surrounding buildings and I would like to map my photos to these basic Revit models. We will then create views at street level as an output.
After looking at Decals and then materials, I wanted to see if there were any other tips or tricks to achieving this? Anyone tried a similar task?
Any advice would be appreciated. Thanks in advance!
sureshchotrani
In Revit under Material you will find Appearance tab on right side, in this there is a option to put image.
With this you can attach the image to object.
After attaching image click on image in Appearance you can play with the available properties in it to adjust the image appearance on the object.
www.bim-3d-4d-5d.blogspot.com
www.bim-navisworks.blogspot.com
Twitter @SureshChotrani
Give KUDOs if happy & accept solution if post provides solution
