Hi
I need help with Phasing...
I have all existing walls in black, new walls no fill. When I put Casework on the Existing Phase, it goes solid black, however I need it to be white/no fill. How to I change this setting. I have it set this way on a different template and I do not know how I achieved this.
Cheers
Gelöst! Gehe zur Lösung
Gelöst von Mohamed-Nassar. Gehe zur Lösung
change phasing mode
and go to visibility and graphics or Object style to control Cut pattern or projection
It could be a couple different things, if the suggestion's above don't solve the issue, an you post some screen captures of your VG setting and you Phasing settings? maybe post the file as well if you can.
Howard Munsell
