Phasing problems need your expertise
14 ANTWORTEN 14
GELÖST
Nachricht 1 von 15
BIM_Dreamer
397 Aufrufe, 14 Antworten
I have a phase 1 and phase 2, when I set the phasing per phase I'm able to see on both phasing the room names, but when I set the phase filter to NONE and phase to ALL the room names are not visible. How can I make them visible. Thanks
14 ANTWORTEN 14
Nachricht 2 von 15
bimscape
als Antwort auf: BIM_Dreamer
Where are you getting the option to see "All" Phases from??? You can only pick one phase at a time from the the drop-down list of available phases
Kind regards,
Ian
Author of The Complete Beginners' Guide to Autodesk Revit Architecture (free online course)
Nachricht 3 von 15
Ilic.Andrej
als Antwort auf: bimscape
I guess @BIM_Dreamer is confusing phases with phase filters.
Andrej Ilić
phonetical: ændreɪ ilich
MSc Arch
Autodesk Expert Elite Alumni
Nachricht 4 von 15
bimscape
als Antwort auf: Ilic.Andrej
Could be. It's just the way he states...
"when I set the phase filter to NONE and phase to ALL...."
We need a bit more info / clarification
Kind regards,
Ian
Nachricht 5 von 15
Sahay_R
@bimscape @Ilic.Andrej - I think that this is what the OP means (with Show All or None as Phase filter....) -
Rina Sahay
Revit Architecture Certified Professional
Nachricht 6 von 15
cbcarch
Rooms do not translate across Phases.
You may need to copy the Rooms from Phase 1 to Phase 2.
What happens when you set Phase Filter in View to Show All? This should show everything in all Phases.
Then try Show Complete? Show Previous & New?, etc.
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Nachricht 7 von 15
BIM_Dreamer
Okay, maybe I didn't explain well, sorry for that. I have a two building adjacent to each other phase 1 and phase 2 with room names each phase. I can make them set (off/on which phase I need to show) by using a phase filter. Now I want to have an overall plan view that can show both phase 1 and phase 2 which I am able to show it but, my issue is the room names disappear how can I set the room names appear on both phases or is that possible or not possible? Thanks
Nachricht 8 von 15
BIM_Dreamer
als Antwort auf: cbcarch
i did try everything your suggestion but doesn't work. thanks
do remember room names has its area paramenter, how i can copy those room names? thanks
Nachricht 9 von 15
cbcarch
If you have not already done so,
Try setting Phase Filter in View to Show Complete, or Show All.
What happens?
Also, is one of the buildings Linked into the other file? If so, check Phase Mapping.
Select the Linked Model, then under Properties, check that Phase Mapping is IDENTICAL in each model.
Cliff B. Collins
Nachricht 10 von 15
BIM_Dreamer
try your suggestion doesn't work. i don't have any linked model. both phases are modelled in the same file.
Nachricht 11 von 15
Sahay_R
Show All won't cut it. You will have to copy the rooms from one phase to the other.
Rina Sahay
Nachricht 12 von 15
BIM_Dreamer
als Antwort auf: Sahay_R
@Sahay_Rthank you for your reply. i think you misunderstood my question.  i already posted above. thanks
Nachricht 13 von 15
Sahay_R
Again - you will need to copy the rooms from one phase to the other. Rooms do not translate from one phase to the other.
Rina Sahay
Nachricht 14 von 15
BIM_Dreamer
thank you for your reply, how can you copy room names and paste, dont forget that  room names has area parameter it will give you a lot of errors.
Nachricht 15 von 15
You select Rooms from one phase, CTRL+C to copy to clipboard, switch the view to the other phase or open a view of the other phase, Paste align to the same place or align to View.  The only warning you will have is if you already have rooms of the same number under the target phase or you already have some rooms in the same place.  To avoid them, create a room schedule of the target phase and delete any rooms that not supposed to be there.
