Phasing on A360 Viewer
5 ANTWORTEN 5
Nachricht 1 von 6
Base12
1947 Aufrufe, 5 Antworten
I was referred by the A360 Viewer tech support team to post my question in this forum to see if anyone here has a solution.  The software is Revit Architecture v2016. The issue is as follows:
A project has various phases set up including Existing, Demolition, and New Construction, Phase-2 Construction, etc.  The Revit file has 3D views established.  All views display appropriately inside of Revit.
Once the file is uploaded to the A360 Viewer site, in addition to whatever Drawing Sheets, there is only one (default?) 3D view available, no matter how many 3D views were established in the local file.  The question is how to display 3D phase views in the A360 Viewer.
Thanks for any suggestions,
JP.
5 ANTWORTEN 5
Nachricht 2 von 6
ennujozlagam
als Antwort auf: Base12
hi, you may check it here some known issues. hope it helps. thanks
Click HERE
Nachricht 3 von 6
KyleB_Autodesk
JP,
Here's how to solve this situation:
  1. Download and install the Collaboration for Revit addon on your machine.  You do not need a subscription to the C4R product to install or follow the steps below.
  2. Open your model in Revit, and use the "Views for A360" button that now appears on the Collaborate tab of the Ribbon.
  3. Define the Revit Views/Sheets that you want to see on your browser/mobile device in A360.  You likely want to set up some Revit Views for each phase, if they don't exist in the Model already.  Save and Close the dialog.
  4. Save the Model.
  5. Upload to A360 Viewer.
  6. Once translation is complete, you now can see the Views you curated back in Revit.
-Kyle
Kyle Bernhardt
Director
Building Design Strategy
Autodesk, Inc.
Nachricht 4 von 6
als Antwort auf: KyleB_Autodesk
Is it possible to do the same with Revit 2018 and a student license?
Nachricht 5 von 6
KyleB_Autodesk
als Antwort auf: Anonymous
Sure is.  With Revit 2018, you don't need to install anything though; just use the "Publish Settings" from the Collaborate Tab.
-Kyle
Kyle Bernhardt
Director
Autodesk, Inc.
Nachricht 6 von 6
shivraj.panaich
How would this work with revit LT 2018.3?
