Phasing Materials
8 ANTWORTEN 8
Nachricht 1 von 9
683 Aufrufe, 8 Antworten
Phasing Materials
Is there a way to phase a material so it only shows up in the "New" phase.
Ex.  I have split-faced my wall and painted it but that paint shows up on both the New elevations and the demo elevations - I only want to show it on the new.
I was hoping for an easy toggle button in the  Material set-up  that would allow me to pick which phase it would  show in... not there... or at least I can't find it.
If it exists someone please tell me
If not, It's a good and simple idea... anyone else agree?
8 ANTWORTEN 8
Nachricht 2 von 9
als Antwort auf: Anonymous
Parts would get you there.
For example, Paint applied as a physical wall layer.  Wall created in Existing Phase, but through Parts, Paint doesn't show up until New Construction Phase.
Nachricht 3 von 9
Instead of split face, create parts from the wall the you can change parts to a different phase and part material to be different from the original.
Nachricht 4 von 9
als Antwort auf: barthbradley
Not sure how I find "Parts"
Nachricht 5 von 9
Select a wall and press this button on the Modify Tab.
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2018/EN...
If this is your first go-around using Parts, you may want to watch some tutorial videos about it.  There's a few on-line that you can get to via a keywords search.  Have fun.
Nachricht 6 von 9
Do you use Revit LT?
Nachricht 7 von 9
Thank you so much for your help - the parts function is a little too much to learn for a Monday deadline.
Nachricht 8 von 9
als Antwort auf: ToanDN
Thank you!
Nachricht 9 von 9
So you have a pre-existing wall condition and a new construction wall condition; right? Why not just do two walll types and phase one out and phase one in then?  Also, since you mention "Splitting Faces", did you know that you can shape-edit a wall profile and embed one into another?  Just a suggestion.
