I have 2 phases in a project, existing and demolished, a wall is being reduced in height. I created the bottom half on the existing phasing and the top half on the demolished.The problem is when I come to add a window it only seems to intersect with one part of the wall. I had change the bottom half of the wall to the same phase as the top to get the window to fully form in. Is there a way round this?
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
I did a quick video since I'm not sure if I am doing exactly what you are doing....see attached.
It works like you show if the window is placed between two walls in the first place. It will cut both automatically.
But if you place it entirely within one wall and move it up or down to meet other wall, it won't cut. hence the join/unjoin trick.
Thanks you understood me I wasn't getting the same results as you.i think as other person has posted because the walls were not joined.."thanks again
