Phasing Graphic Override not Applying to a Roof Plan?
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
zacharytbroussard
270 Aufrufe, 3 Antworten
Hello, new to Revit. Have an easy question I can't find answered anywhere online.
I set up a model to have an "Existing" and a "New" Phase.
I then applied a colored surface pattern graphic override to the "New" phase status in Manage > Phasing > Phases > Graphic Overrides. It looks like this:
I then set the filter options for the phase filter "New + Existing" to "Overridden" for New Phases in Manage > Phasing > Phases > Phase Filters. That screen:
Now, in every view that I set to "New + Existing", the New Construction phase work appears in blue, which is perfect. It works in floorplans, sections, axons, and elevations.
My only problem is that the phase filter override is not applying to any of my roof plans, of which there are 4. It's only NOT applying in these roof plans. Does anyone have any idea why they're not applying in roofplans? Does it have something todo with View Range?
Thanks in advance.
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: zacharytbroussard
Make sure the Primary Range's Bottom of the Roof Plan is lower than the roof.
Nachricht 3 von 4
zacharytbroussard
als Antwort auf: ToanDN
that was it! thanks.
Nachricht 4 von 4
Are your Roof Plans actually viewing Roofs - or are they viewing symbolic representations of the Roofs or showing Roofs via an underlay?  Any View Graphic Overrides applied to the Roof (By Element, Category or Filter)?
