Phasing Graphic Override Issue?
jvalaleducation
jvalaleducation
If I understand phasing graphic overrides correctly, if I change the graphic override for "new" to say, green, then I would expect the "new" items to be green, right? But when I do this, the opposite occurs. When I change "new" to green, the existing walls turn green. Please see video >>
RDAOU
@jvalaleducation
It depends on the phase which you have set. It a combination of pause and phase filter.
New means the element was created in the current phase you have set. Ie:
  • if the phase of the view is set to Existing, all elements created during existing will be green.
  • when u switch phase to new construction, the elements created in the previous phase will be (ex: gray) and all elements created in new construction will be green
Sleepingfish_Kuo
For your "Existing" phase view, the elements in "Existing" phase are not existing elements, but new elements.
They are just creating in current phase in the view.
Try create another view and set the view phase to other phases.
