Phasing for Multistorey Stairs
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
103077382
265 Aufrufe, 3 Antworten
Hi does anyone know how to change the phasing for mulistory stairs. Accidently modelled them in new construction and need them changed to existing.
3 ANTWORTEN 3
Nachricht 2 von 4
Simon_Weel
als Antwort auf: 103077382
Select the stairs and then press Tab to select the actual stairs. Now you can set the properties.
Nachricht 3 von 4
handjonathan
Hi @103077382
Thanks a lot for posting your question to the forums!   Has the solution suggested by @Simon_Weel helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
Nachricht 4 von 4
103077382
als Antwort auf: Simon_Weel
Thanks Simon yep this solved it!
Cheers
