We are working on the second phase of a project, whereby we are using many of the same partition types, door types etc. We are using both phasing to differentiate between that which we had built previously (now 'Existing') and that which is new ('New' phase). We are also using Visibility filters to distinguish between the types of partition (IP-1, IP-2 etc..) All the partition types exist in both the previous 'Existing' phase and the New phase. We would like to apply the visibility filters ONLY to those items which are in the New phase. We have created another 'text'-based, instance parameter, which if it does not contain the word 'New', it will ignore from visibility filters, i.e. changing to red for instance. Surely the phase condition could be added to the Visibility filters?? i.e. If Type Mark == IP-1, and if Phase == 'New Construction', then make lines and fills red.
do you have your Existing view with all your existing partition set to phase created in "Existing"?
do you have your New view with all your New Partitions set to phase created in "New"?
what are you using for your Phase filters in their respective Views?
Existing= show all
New = Previous and New
without using any filtering this method should provide you with a result of all Existing shows up bold in your Existing view
All your New shows up bold in your New view and all existing shows halftone or Lighter in your New view.
check you phase filter graphic overrrides
if this is correct then you can apply any other filters you are looking for.
the image displays the contrast between New and Existing.
I hope this helps.
If you are using Coarse scale fill pattern in lieu of Visibility filters to distinguish partition types then you can use Phase graphic override to distinguish the same partition types under different Phases.
Hi @kadmonkee
Try applying a different graphic display or override to the elements in a phase status.See phase workflow.
Define graphic overrides as needed to change the display of elements in views that use phase filters.
Phasing panel
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
