Phases overlap
4 ANTWORTEN 4
Nachricht 1 von 5
mairh_tsek
700 Aufrufe, 4 Antworten
Phases overlap
Hello all,
 I have in the same place a demolish wall and a new wall.
I have applied overrides in both of them. The problem is that the demolish wall hide the new constuction wall.
What can I do in order to see the new wall in a front plan?
Thank you in advance!
4 ANTWORTEN 4
Nachricht 2 von 5
AFatRat
als Antwort auf: mairh_tsek
Set your view's phase filter
Nachricht 3 von 5
Set your View's Phase Filter to Show Complete.
Some light reading about Phase Filters and Graphic Display:
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2018/EN...
Nachricht 4 von 5
- If you want to see the new walls and the existing walls with distinguishable graphics then change Phase filter to Show Previous + New.
- If you want to see the new walls and the existing walls with the same graphic then change Phase filter to Show Complete.
Nachricht 5 von 5
mairh_tsek
als Antwort auf: ToanDN
Thank you for your answers,
I want to see the demolished + new and existing elements in a plan.
But If in Phase filters I have the NEW and DEMOLISHED Overriden, the demolished elements ovelap the new .
