Phase problem
8 ANTWORTEN 8
GELÖST
Nachricht 1 von 9
mairh_tsek
895 Aufrufe, 8 Antworten
Phase problem
Hello all,
I have some walls with multiple layers. When I have the phases override I cannot see the layers.
How can I see the layers of the wall with a red colour?
Chech the images.
Thank you in advance!
8 ANTWORTEN 8
Nachricht 2 von 9
htews
als Antwort auf: mairh_tsek
change your Phase Filter in your template to  'Show Complete'.
Nachricht 3 von 9
Well, there are  two things you need to do: 1) add a solid Red Fill Pattern to "New" Projection/Surface and Cut under Graphic Overrides tab, and 2) change "By Category" to "Overridden" under the "New" Column on the Phase Filters tab
Here's an example of a solid red Graphic Override applied to "Show New" Phase Filter
Nachricht 4 von 9
s.borello
Try changing your phase filter to "Show All" or "Show Complete"
Nachricht 5 von 9
...or is this what you are after?
Nachricht 6 von 9
Change the overridden materials to By category.
Nachricht 7 von 9
,,,or maybe this is what you are looking for?
Pretty much anything is possible through Graphic Overrides and Phase Filters. Just depends on what you want.
Nachricht 8 von 9
mairh_tsek
als Antwort auf: barthbradley
I need the result in the image below.
But what can I do if I want only the new  walls to be in red and not all the new elements?
I need to use filters?
Nachricht 9 von 9
That's exactly what I showed in Post #5. Yes, you need to assign the Graphic Override to a named Phase Filter - just as I showed in Post #3 and as @ToanDN  showed in Post #6.
