The existing phase graphic override option is working but for the same project , the new construction graphic override option for line projection color wont work . i had to change the line color manually for the entire work . Can somone help
Gelöst! Gehe zur Lösung
Gelöst von chhuanmawia18. Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
check proprieties tab for what phase you are showing
Ahmed Muharram, B.Sc, AEE, ACI, ACP
BIM Manager
Do you have other Graphic Overrides in place? Sounds like you might.
