Phase filter: Color
9 ANTWORTEN 9
GELÖST
Nachricht 1 von 10
XXalessio.amodioXX
6442 Aufrufe, 9 Antworten
Phase filter: Color
Hi all,
I would like to prepare a filter per each phase of my project and assign a color to it (e.g. Phase 1 - Red, Phase 2 - Blue...)
Any idea?
9 ANTWORTEN 9
Nachricht 2 von 10
als Antwort auf: XXalessio.amodioXX
Consider using the phasing tools.
Nachricht 3 von 10
I'm guessing you want to show different phases in one view?
Nachricht 4 von 10
kadmonkee
it can work as long as the shared parameter you use for Phasing is assigned to all the categories you want to display in their respective phase.
Desk = Phase 1 = red
Desk = Phase 2 = blue etc.
this method works in all views with those filters active in the views regardless of the phase mapping
it is an override filter
If there is any information shared that is of value please give Kudos
If a solution is provided by any posters please mark them as Solved to benefit everyone else.
thank you
Nachricht 5 von 10
Create a working view and Set the view to a phase and phase status to new, select everything and save a selection set. Repeat for every phase. Open the presentation view, add the selection filters and change color for each.
Nachricht 6 von 10
Exactly but differenziate them by color.
Phase filter is not working properly because it can be filtered just the previus phase.
I cannot create a Filter per elements related to a phase (Phase parameter does not appear in drop down menu)
Nachricht 7 von 10
XXalessio.amodioXX
als Antwort auf: kadmonkee
If I create a Shared parameter e.g. XX_Phase. It will appear in drop down menu in Filtering option?
Nachricht 8 von 10
XXalessio.amodioXX
als Antwort auf: ToanDN
It is a good idea but It is not "Parametric."
It means that each time I model a new element with related phase I must change the filter selection.
Not handy
Nachricht 9 von 10
You can follow above directions by Toan^^^, that's your best option to filter by selection set.
Alternatively you could overlay different views on a sheet, however that doesn't work quite as well.  Phase filter is also requested on ideas forum in multiple topics, you could find these topics and vote for it.:)
Nachricht 10 von 10
kadmonkee
you can use the default parameter (comments) set the trigger to define the phase in comments
Phase 1 = Red
Phase 2 =Blue etc.
I chose to make a shared Parameter(s) and assign that to all my phasing needs when I am dealing with more complex models and the regular Phase mapping wont accomplish what I need
thank you
