Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Phantom duplicate linework in Revit 2013 project
5 REPLIES 5
casquatch
636 Views, 5 Replies
Not sure what to categorize this as, throw it under another 2013 oddity.
We have a project that has some filled regions causing graphics issues. What happens is the plan elements around a filled region are being transposed onto the filled region causing a "ghosting" affect on the filled region. See attachment.
Has anyone else had this issue? It is happening in both Arch and MEP and I've tested it with update 2 and update 3 installed. No changes with an audit either.
Any other ideas?
Casey
5 REPLIES 5
rosskirby
in reply to: casquatch
Possible graphics card issue?  What are your system specs?  Have you updated your drivers?
Ross Kirby
Principal
Dynamik Design
www.dynamikdesign.com
casquatch
in reply to: rosskirby
Updating the driver worked like a charm. Thank you Ross.
I even tried it on a couple different machines and with hardware acceleration on/off. Oh well, at least it was an easy fix!
Thanks again!
rosskirby
Glad that helped.  Just out of curiosity, and as assistance to future users who may do a search and come across your post, would you mind posting what video card you were using, and what driver you updated to?
Ross Kirby
Principal
Dynamik Design
casquatch
No prob. The graphics card is an NVIDIA Quadro 2000 and the driver version has been updated to 320.49 with a release date of 2013.07.03.
This was on a Win 7/x64 machine.
rosskirby
Perfect, thank you.
Ross Kirby
Principal
Dynamik Design
