Percentage of Totals in Schedule
hliS658H
hliS658H
I need to calculate wall opening percentage in the schedule. I use filled region, one type for opening area, one type for the exterior wall.  How can I edit the schedule to make it look like below? The formula will be based on two totals, not sure how to do that.
d.ahmed.LW
there is no way to add a customized total directly in schedule as a row but there are other workarounds that could help. I would suggest you to have a look at the below thread.
Please mark the solution if it helps.
Re: Add a row inschedule for percentage calculation - Autodesk Community - Revit Products
Why can't you just include the Open Percentage Column and Total that Column? You can have both Total Exterior Wall and Open Percentage totals.
linkboy
