pendant light vertical on sloped ceiling
4 ANTWORTEN 4
Nachricht 1 von 5
Ashley_Richardson
828 Aufrufe, 4 Antworten
Is there a way to keep pendant light hanging vertical on sloped ceiling in revit?
4 ANTWORTEN 4
Nachricht 2 von 5
RSomppi
als Antwort auf: Ashley_Richardson
Yes, but it's not a simple answer and can vary depending on your requirements.
Nachricht 3 von 5
hmunsell
  • place it on a reference plane set to the height desired.
  • add parameters to the light to adjust the pendent length
  • adjust the pendent length to meet the ceiling.
    • may need to add a angle parameter to rotate the escutcheon to the angle of the ceiling.
Howard Munsell
Nachricht 4 von 5
The easiest way is use two families:
- Mounting plate: face based family, hosted by the sloped ceiling
- Pendent light sans the mounting plate: work plane based, always vertical, hosted by the bottom of the mounting plate
Nachricht 5 von 5
Maybe use a Ceiling-Hosted Family (with "Always Vertical" checked) instead of a Face-Based Family.  There's plenty of them out there to choose from.  BIMObject.com is a good place to find a bunch, FWIW.
