PEMB frame - from Revit City
8 ANTWORTEN 8
GELÖST
Nachricht 1 von 9
8164 Aufrufe, 8 Antworten
I found this at Revit City. Can someone help me fix this family?  The slope parameter is not flexing correctly.
Thank you
Matthew
8 ANTWORTEN 8
Nachricht 2 von 9
als Antwort auf: Anonymous
And.....the reason why families from Revit City are not allowed in any of our projects.  People upload families that have not been tested first.
Nachricht 3 von 9
I should have lead with:
I am a 1 person shop and I have been using Revit for 6mo. Families are still daunting.
Nachricht 4 von 9
johntyson3407
Try this one. We do Pre-Engineered Metal Buildings quite a bit and this family isn't perfect, but it works.
Nachricht 5 von 9
als Antwort auf: johntyson3407
That works great. It does more than I could have hoped.
Nachricht 6 von 9
The one from Revit City used reference planes for the slopes...which will break once flexed.  @johntyson3407's version is much better.
Nachricht 7 von 9
jskopec5X3K5
I don't suppose you're still out there somewhere lol? We use this family quite often, thank you first and foremost! However, it appears it can be used for single slope/flat option, but just not sure how. I have played with this quite a bit, not sure how both frames shown work with options?
Nachricht 8 von 9
johntyson3407
als Antwort auf: jskopec5X3K5
Still here!
It was a while ago, but I think I remember it being too much trouble to get the all-in-one family we were striving for. Try this one for mono slope applications. Set the slope to 0 for a flat option, works great for portal frames.
Nachricht 9 von 9
jskopec5X3K5
I had just gotten to the point of WAY too much trouble, with trying to make it work all around lol! This is perfect though, thank you! I swear I'm going to figure it out, I will share if/when I do!
