PDF Slow to Open
11 REPLIES 11
Message 1 of 12
jvalaleducation
476 Views, 11 Replies
PDF Slow to Open
Hello - Any PDF I create in revit is super slow to open and my clients aren't too excited about the experience. The file is only 20MB and no matter what PDF program I try to open in it, hogs all the computer resources.
Any help??
Tags (3)
11 REPLIES 11
Message 2 of 12
syman2000
in reply to: jvalaleducation
It is because the PDF reader have to process all those dense hatch. Try to remove them or change to different hatch if you can.
Message 3 of 12
jvalaleducation
in reply to: syman2000
really? Even though the PDF's only 20MB?
Will give it a go.
thanks
Message 4 of 12
Only 20 MB?  That PDF should be around 200 KB.  Get rid of the gravel pattern or make it way less dense.
Message 5 of 12
I changed the hatch, but didn't compress it at all now. It's back up to 40+MB, still slow to load.
Message 6 of 12
have you try any PDF driver like cutePDF writer and see if helps? thanks
Message 7 of 12
Yes, I've tried a few options to shrink it. Though there should be no issue with even a 20MB file. I can get the file down in size, but it's still slow to open and still probably shouldn't be 20MB.
Message 8 of 12
syman2000
Still the hatch is there. When I am import the PDF into AutoCAD, it shows the file has over 2 millions lines.
Message 9 of 12
jvalaleducation
You can see I reduced the hatching. Is there a way to figure out what's generating all the polylines??
Message 10 of 12
syman2000
Try turning off the hatch for the floor and do a PDF print. Tell us the size without those hatch.
Message 11 of 12
Got it! Wasn't the exterior hatch. Was an interior one.  That being said. A 20MB file still shouldn't be that resource intensive. IMO.
thanks all
Message 12 of 12
It wasn't the file size... It was the hatch. Did you see the comment above that there were over 2 million lines?
Forma Design Contest
