PDF Printing Multiple Sheet not working
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
1523 Aufrufe, 4 Antworten
Somehow Printing Multiple sheet and combined function is not working. The file location is correct but nothing happened after I clicked the "save" button, nothing was printed. The printing function would only work if I select "Create separate files"
4 ANTWORTEN 4
Nachricht 2 von 5
ennujozlagam
als Antwort auf: Anonymous
try another printer driver like BULLZIP to print and see if helps. thanks
Nachricht 3 von 5
Use CTRL + P to print, not Print button.
Nachricht 4 von 5
s.borello
reboot!
Nachricht 5 von 5
syman2000
Since you are using Adobe PDF, I like to know what is your print quality output. Normally if you set it to 1200DPI and print a huge set, most likely your cache will run out memory and it won't print. So you may want to keep it to min 300DPI and try printing them.
