PDF printing issues in Revit Fatal Error
georgehobel
Message 1 of 11
georgehobel
WHEN WILL THE REVIT PEOPLE STEP UP AND SOLVE THE PRINTING TO pdf PROBLEMS... it's unreal how often I get this fatal error message..
George Hobel
Reflections of Charlotte
Residential Building and Design
Replies (10)
Message 2 of 11
cbcarch
-Are you "batch printing" many, many sheets at once?
-Depending on how complex the graphics are, and how much RAM your computer has, results will vary on successfully printing lots of sheets at once.
-This is not a "Revit" problem--same thing can happen in other programs when graphics demands exceed hardware limits.
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Message 3 of 11
RobDraw
Revit cannot print to PDF without 3rd party software. They have no control over it. I've printed to PDF with several different PDF printers without issues. So, again, not a Revit issue.
BTW, the complaint department is down the hall to the left.
Rob
Message 4 of 11
georgehobel
Ive been to the complaint dept. already... there was a sign on the door that said check your pronouns at the door..... I wouldnt enter.
George Hobel
Message 5 of 11
Print a set as separate PDF files and see where it gives the error.
Message 6 of 11
georgehobel
I was trying to print as seperate files... with Adobe.  fatal error twice in a row.  Unfortunately, I quickly clicked "no" when promted to save a recovery file.... argh... thank goodness Revit saves periodically, only cost me 15 min. or so.  Each time it failed it had gotten to about page 6 or 7 of a 17 page set.. I do not know why they failed... third time it worked, with no changes made in my procedure.. "control P" didnt help..
If its the PDF program.. what's another one I should try?  My subscription to Adobe is up anyway....
George Hobel
Message 7 of 11
- What are on page 6 or 7?
- Set the Adobe PDF printer to not open printed PDF automatically
- Try Bluebeam (paid), PDF Creator or PDF Architect (free with occasional pop-ups) and see what works
- Save before print
Message 8 of 11
georgehobel
My drawings are really pretty simple... there are no imported CAD or Revit files.. , just drawings and some families... There is nothing on any of the pages that arent also somewhere else... I'm going to give bluebeam a shot...
George Hobel
Message 9 of 11
cbcarch
-FYI....Revit does NOT autosave.
It may send a message prompting you to save.
-Also, per your comment--"it had gotten to about page 6 or 7"--this sounds like you are trying to print multiple pages 1-17., --batch printing. (i.e. not opening a single sheet, then printing/saving a single PDF of just that sheet.)
Depending on how much RAM your PC has, you may or may not be able to print 17 sheets in succession.
-Yes--Bluebeam is the industry standard in the AEC market with Revit. It works very well and has nice features for editing/extracting/combining/adding pages, markups, etc. It even has an available "Bluebeam Studio" function
where multiple users can collaborate and markup/comment on PDF drawings.
Cliff B. Collins
Message 10 of 11
georgehobel
Thank you Cliff... I do know i need to upgrade my computer, but the fatal error thing happens on large projects, small projects, and sometimes not at all...
I have started a trial version of blue beam, and like it so far....very powerful.
George Hobel
Message 11 of 11
Viveka_CD
Hi @georgehobel
There are several known pdf/text issues. Most have things to do with the display on the computer, graphics cards etc.
Here's a bunch of issue with pdf printing listed here: https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
