PDF Print Skipping Lines
1 ANTWORT 1
Nachricht 1 von 2
bosborne
459 Aufrufe, 1 Antwort
I am having a PDF printing issue that I cannot find a cause nor a solution to.  See attached image.  This looks fine on the screen, but when printed to PDF - it seems like there are missing vertical lines of pixels at a seemingly regular interval.  I've tried Vector and Raster printing, different computers, different PDF printers, different DPI settings, XPS printer - all did the same thing.  Anyone else ever experience this (and have a solution for it)?
Tags (3)
Beschriftungen (3)
1 ANTWORT 1
Nachricht 2 von 2
TripleM-Dev.net
als Antwort auf: bosborne
From reading the post it would be something with the Project and not hardware/software related.
Maybe the view is corrupt (normally that would be visible in the Revit though)
Try a couple of standard things to do/check (non-specific order):
- Audit Project
- Recreate view from scratch (DON'T Duplicate view!)
- Any DWG's (or other CAD's) linked/inserted with large coordinates or geometry (and is/was visible in view)
- Any large coodinates/geometry at all.
- Michel
