PDF print result with linked model
4 ANTWORTEN 4
Nachricht 1 von 5
453 Aufrufe, 4 Antworten
Hello All,
we have bad pdf print results with our combined 3D-Model.
If we print the pdf from the architectural Model with linked MEP Model, there is no Problem.
We have a seperate facade Model, which should be displayed in the pdf.
If we link the facade Model to the architectural Model, we get bad print results.
You can see it in the picture. The Lines are not displayed really good.
bad quality with linked facade modelbad quality with linked facade modelgood quality without linked facade modelgood quality without linked facade model
The only difference between the two pdfs is the linked facade model.
There where no changes in the printer settings.
We tested with different pdf printer drivers, but always got the same result.
Has anyone an idea why we get the bad quality with facade Model linked?
Note: If we copy the facade model in the architectural model, the print results are good, but the performance is getting bad.
I hope you understand, what we need - my english is not the best :grinsendes_Gesicht_mit_lächelnden_Augen:
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: Anonymous
Does the facade model have a coordination navisworks link?
Nachricht 3 von 5
als Antwort auf: ToanDN
No, the facade model has no link to navisworks.
Nachricht 4 von 5
Is the Link set to display by Host View or by Linked View under V/G?
Nachricht 5 von 5
That was my first idea, too. We tested both, but got the same result :verwirrtes_Gesicht:
