PDF Import crashes Revit
4 ANTWORTEN 4
Nachricht 1 von 5
steve
688 Aufrufe, 4 Antworten
When I import PDF file, revit crashes without notification. When I try import image file of any description the spinning wheel appears and stays like that
4 ANTWORTEN 4
Nachricht 2 von 5
ennujozlagam
als Antwort auf: steve
try to import pdf in autocad drawing and link into revit and see if helps. thanks
Nachricht 3 von 5
steve
als Antwort auf: ennujozlagam
Hi that does work, however it is another step in my documentation that I
would like to avoid.
Previously import pdf file worked great and I was able to snap to ends etc.
but for some reason it no longer works.
Nachricht 4 von 5
steve
I have found that the problem exists within my user logon for windows. I have another logon on same computer and import pdf into revit works fine. There are issues with email and access to network drives but they can be fixed.
Nachricht 5 von 5
murray
Im having the same problem, inserting a pdf crashes Revit 2024
