PDF export using sheet number parameter
5 ANTWORTEN 5
GELÖST
Nachricht 1 von 6
Rudolf_Wilhco
478 Aufrufe, 5 Antworten
In previous versions of Revit I could set up our file name convention of project name_sheet number_sheet name(Revision)(sheet size). In the current 2025.2 the sheet number parameter doesn't work for pdf export. The sheet number parameter works everywhere else, ie drawing list, tags and browser organizer.
Am I missing something?
5 ANTWORTEN 5
Nachricht 2 von 6
jay_colcombe
als Antwort auf: Rudolf_Wilhco
Hi I have just repeated as a test and cannot replicate it unfortunately - is the sheet Number Reference in your sheets the generic OOTB Labe/Parameter?
Also are you using the Sheet Number from the View?
As you can see here it pulls the Sheet Number from the Sheet but not the one from the View
Jay Colcombe
Autodesk Certified Instructor
Nachricht 3 von 6
Rudolf_Wilhco
als Antwort auf: jay_colcombe
Hi. Yes Im using the OOTB parameter/label in the sheet. I have also deleted the old and replaced again. This very same sheet and project file worked perfectly fine in Revit 2024.
I have also tried this in other projects on Revit 2025 with the same result. All of which worked in 2024.
Using the sheet number as filter in other areas such as organizing and sheet list, works perfectly fine as well
Screenshot 2024-09-02 074708.jpgScreenshot 2024-09-02 074730.jpgScreenshot 2024-09-02 074852.jpg
Nachricht 4 von 6
Rudolf_Wilhco
I see my mistake. I was using the 'Sheet Number' from the 'View' drop down and not the ' Sheet' drop down
Nachricht 5 von 6
jay_colcombe
That’s why I mentioned it in my initial reply - it has caught a few people out!
Glad we got solved the issue!
Jay Colcombe
Nachricht 6 von 6
handjonathan
Great work @Rudolf_Wilhco & @jay_colcombe
I'm glad you got this all sorted. It caught me out in the past :leicht_lächelndes_Gesicht:
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
