I'm receiving PDFs created from Revit files that add unnecessary complexity. For example, a filled circle with an outline in Revit turns into a filled rectangle masked with a circle and a separate circle with an outline only. A single shape turned into three shapes. Sometimes it even turns lines into long filled rectangles with thin, line-sized masks.
I've attached an examples of a simple PDF and a complex PDF.
All these extra objects and masks make the file very hard to use. I'd love to know what settings I could tell the client to change to keep the PDFs simple.
adding what ToanDN mentioned, export to pdf by clicking the top icon:
https://help.autodesk.com/view/RVT/2024/ENU/?guid=GUID-773AD069-024B-425E-8B9A-05D5246BDD16
I usually use raster process to prevent from missing elements
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | Especialista BIM
Autodesk Certified Professional
Do you have two View on each other or this is just one View?
Thanks a lot for posting your question to the forums! Have the solutions suggested by @ToanDN @vitorbortoncello @barthbradley @azad.Nanva helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community!
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
Is that different from what most architects do? Are there any settings to change? I want to make sure I understand what I'm asking them to do.
Sorry, I receive the PDFs, but I don't know anything about how they've set up the original files. What effect would that have?
