PCP, Revit and Autocad
2 ANTWORTEN 2
Nachricht 1 von 3
jewongVB7C5
2160 Aufrufe, 2 Antworten
I understand when Revit exports to DWG, it also exports a PCP file along. Within autoCAD I could convert this PCP file into a Plot style pen table. But when I print using this pen table, I DONT get my pen thickness, etc. similar to Revit. Is there any reason for this not to work.
These are the things I tried:
1. I had tweaked the import/export settings in Revit. So, I went ahead and imported the AIA std pen settings and tried creating a CTB file. Still does not work.
2. Within autocad I AM selecting the "Plot with plotstyle" option. Still the printed sheet from autocad is very different from Revit.
Any thoughts.
Thank you in advance.
John.
2 ANTWORTEN 2
Nachricht 2 von 3
RSomppi
als Antwort auf: jewongVB7C5
You might have better luck asking how to use the .pcp file over in the AutoCAD forum.
Nachricht 3 von 3
Did you convert PCP to CTB correctly?
http://revit.blogspot.com/2010/05/revit-pcp-files.html
