PBR Graphics - Scale
5 ANTWORTEN 5
Nachricht 1 von 6
LFBIMMAN
335 Aufrufe, 5 Antworten
Very new to PBR graphics. When setting the scale, should I be setting this to the same size as the picture?
for example height & width pixels of the image are 1024(W) x 1024(H). so in Revit set the scale of each image to 1024mm (W) x 1024 (H)?
Happy to hear any other tips you have for setting up PBR graphics too :leicht_lächelndes_Gesicht:
5 ANTWORTEN 5
Nachricht 2 von 6
als Antwort auf: LFBIMMAN
You're looking at 2 different things.  The scale in the texture editor is the size of the image tile in model space (1:1).
Help | Texture Editor | Autodesk
Nachricht 3 von 6
syman2000
If you want to know the pixel to millimeter, check this conversion site. Normally pixel has value which isn't equal to real world measurement.
https://www.unitconverters.net/typography/pixel-x-to-millimeter.htm
For PBR material setup, check Revitkid video
https://www.youtube.com/watch?v=kNKMZksHMBg&ab_channel=TheRevitKid
Nachricht 4 von 6
LFBIMMAN
als Antwort auf: syman2000
That pixel converter instantly just made a big difference to the quality! thanks will watch the video too.
Nachricht 5 von 6
6" Square Tiles
Nachricht 6 von 6
Pixels are to indicate the quality of the image. Dimensions in the asset editor are to set the size to be applied in the model.  They are two different things altogether.
