Patterns & Colors on the Same Material
I'm looking to use both a pattern and a color on the same material.  For example, I'd like a dark green crosshatch over solid light green background.  Similar to the image attached, but green not gray.  Is this possible to do?  It seems like it's an either/or scenario.
-Jon
L.Maas
Yes, something should be possible. Both in shaded view (1) as realistic view (2)
For 1 you can use a colored surface pattern on the shading color.
For 2 I used a tile pattern were you can set tile and grout color
Louis
Please mention Revit version, especially when uploading Revit files.
RDAOU
Just a small added note: Do duplicate the Material and then the Assest before editing it in Texture Editor
Got it.  For Materials I was using the default gray color in Shading and using the Hidden Line Graphic Display, which was what was throwing me off.  Thanks for your help!
