Pattern based curtain panel along the devided curved irregular surface
0 ANTWORTEN 0
Nachricht 1 von 1
vicktor1111111
66 Aufrufe, 0 Antworten
Good day! I'd like to ask how can I make separate elements of the pattern based curtain panel allign with the curved irregular surface like this:
Whereas the pattern based curtain pattern is this:
Which consists of the numerous separate elements (tiles).
The problem however is that this pattern was created with the much narrower pattern based curtain panels, and represents rather a workaround than a universal solution:
Which already shrinks (in this case) the variaty of colours of the elements (tiles). If the elemets had to have different shape, it would be even more noticeable. Apart from that, even this workaround wouldn't resolve the problem if the surface was undulating in both, horithontal and vertical, diretions.
So the question is whether it's possible to make separate elements of the pattern based curtain wall  allign with the surface?
Thank you very much in advance!
P.S. Also, even if the surface which is to be divided and which the pattern based curtain panels are to be applied to is flat, there is still a problem with the inner openings, like windows:
If the devision lines don't cross or cross only ever so slightly the openings (i.e. openings are located within the division lines) then the openings would be missed:
Beschriftungen (1)
0 ANTWORTEN 0
