Pattern based adaptive component help
studioZEUUW
studioZEUUW
I am trying to edit a pattern based curtain / drapes family to improve the 2D performance. Currently it seems to fail to produce the 2D linework in radii that are too tight.
So I am editing the family, starting with this:
I am trying to reduce the number of points in both curves to hopefully get a better result in plan.
I tried editing the array of points but that didn't work.
So I tried redrawing the spline with fewer points. I tried to create the same element I deleted, a reference line, but it appears black instead of green. And it's missing some of the other elements that appear whenselected.
Of course this didn't work. How can I revise the family to have fewer curve points?
Basam.Yousif
Can you send me this file?
Or possibly model it outside of Revit?
