PAT Files- Where to get them and why don't they load properly
Message 1 of 8
Fun start to the week with some PAT file issues. I am downloading crushed stone PATs from Revitcity, and they load as a bunch of jagged lines instead of the demonstrated stone texture.
1. Why doesn't Revit give us basic PAT's like crushed stone/ pea stone. I am not finding them in the library
2. Check the screen shot. is it an obvious fix for these to not load improperly?
3. Please link some good PAT's if you can
https://www.revitcity.com/downloads.php?action=view&object_id=3121
Replies (7)
Message 2 of 8
syman2000
Try to scale them up. I know some of the pattern are created using metric unit and it may mess up the pattern value when it is set to Imperial unit.
Message 3 of 8
RobDraw
Sorry, not gonna sign up just to download the file. Can you please share the file for testing?
Revit is not an all inclusive program.
It might be. It's hard to tell without being able to test the file.
Rob
Message 4 of 8
syman, did you see my screen shot? when I try to load that pattern, it imports incorrectly. It looks like you didn't have any issues.. what was your process?
Message 5 of 8
syman2000
It is your import scale.
Message 6 of 8
I had to delete and then bring it back in. The original file, when bumped to 12, would just stretch and still look incorrect. Thank you so much Link. Now go get the princess
Message 7 of 8
syman2000
You can still use value like 2.25 that still looks good. Once you go below 2, it will start breaking up.
Message 8 of 8
Pattycake_Kyle
Hey @Anonymous
www.pattycake.io might be able to help --- We currently have the largest free library of PAT files (over 300+) and an additional 300+ available to our Pro users.
Just have to create a login to download. Take a look and let me know if we are missing something you could use and I can get on creating for you. Feel free to reach out directly to hi [at] pattycake.com -- Cheers! 🎂
www.pattycake.io
Web based & real time .PAT creator. The largest collection of free PAT files! Over 700+ Pat files ready to download
No plugins or add-ins to install, and Revit compliant!
