I am trying to create a custom pat file and not having luck. It is a stretched hexagon. I started with a honeycomb pat file that I found on revitforum, but now I need something more accurate. I tried writing my own, but it tells me no pattern found. I have attached my file so far, as well as an image of my desired shape (custom tile). I don't know why pat files confuse my brain so much.
Thanks!
Gelöst! Gehe zur Lösung
Gelöst von hugha. Gehe zur Lösung
Assuming no gaps, try this:
; Written by HatchKit Professional
; HatchKit Professional (c)1990-2016 Cadro Pty Ltd
; www.hatchkit.com.au/
;-Date : 2017-05-05
;-Time : 1:41:28 PM
;-HatchKit Version : 3.1.9.2674
;-HatchKit Output Filetype : Revit with HatchKit Add-In
;%VERSION=3.0
;%UNITS=INCH
*honeycomb
;%TYPE=MODEL
39.2894068625,0,0,257.375981862,-1.2664755805,14.213,-341.103760089
0,11,9,25,-9,14,-36
-39.2894068625,0,0,97.940778227,-1.2664755805,14.213,-341.103760089
There are only three segments because the template arrangement can be skewed rather than rectangular.
hth,
Hugh Adamson
Hey! Great pat file. Works like a charm. I tried to recreate it for a symetrical hexagon with 12.5sm side, but I couldn.t figure out how you got the numbers in red, so I couldn't calculate them in my case. Could you help out and explain how to get the needed numbers? Thanks a lot.
The regular hexagon pattern HONEY in ACAD.PAT could do the job for you.
*HONEY, Honeycomb pattern
0, 0,0, .1875,.108253175, .125,-.25
120, 0,0, .1875,.108253175, .125,-.25
60, 0,0, .1875,.108253175, -.25,.125
Scale all numbers on each line (apart from the first number - the angle) to suit.
Hugh
It worked. Thanks!
Do you generate them automaticaly and is there a free software that does that from a drawing, or you have to do the calculations yourself?
@Anonymous wrote:
It worked. Thanks!
Hatchkit automatically generates the pattern from a drawing.
You can try that out by running our demonstration version available here.
The full version however is not free.
best,
Hugh
Can someone make this a hatch? I have figured out everything but the delta x,y for the 30 degree lines, I can't figure out.
This nested fill uses a 70 deg bevel at either end of a 5.5" x 3" tile.
; Written by HatchKitCS
; HatchKitCS (c)1990-2016 Cadro Pty Ltd
;-Date : 23/08/2017
;-Time : 5:11:54 PM
;-HatchKitCS Version : 3.1.10.2730
;-HatchKitCS Output Filetype : Revit with HatchKit Add-In
;%VERSION=3.0
;%UNITS=INCH
*Entities,DXF Entity Section
;%TYPE=MODEL
0,0.54596,0,4.9540446486,-1.5,4.4081,-5.4999892972
70.0260904519,0,1.5,319.184266954,0.0445555050545,1.5963,-331.968181597
-70.0260904519,0,1.5,319.184266954,-0.044555505054,1.5963,-331.968181597
This pattern consists of 3 elements on a skewed arrangement whereas a rectangular arrangement would require 6 elements.
hth
hugha,
Thanks so much. It works perfectly! I just couldn't figure out the x and y offsets.
Sorry not getting how you get some of the numbers, can you explain it a little more? I have a tile pattern the designer wants in the file. It is 8" tall x 6" wide but in a hexagon pattern angle is 63.43495.
Don't understand how you obtained these values 39.2894068625,0,0,257.375981862,-1.2664755805,14.213,-341.103760089
Happy to:
Result:
; HatchKitCS (c)1990-2017 Cadro Pty Ltd
;-Date : 16/11/2017
;-Time : 10:40:28 AM
;%VERSION=3.0
;%UNITS=INCH
*8by6hexTile
*;%TYPE=MODEL
63.434948823,0,0,4.472135955,-1.490711985,3.7268,-11.18031985
0,1.6667,3.3333,-3.xxx-xxxxxxxx,-3.xxx-xxxxxxxx,1.6667,-4.xxx-xxxxxxxx
-63.4349488228,3.3333,3.3333,10.434983895,-1.xxx-xxxxxxxx,3.7268,-11.18031985
hth,
Hugh
The posted pattern is wrong - blaming my new glasses ![]()
Try this instead:
;-Date : 16/11/2017
;-Time : 12:05:35 PM
;%VERSION=3.0
;%UNITS=INCH
*8by6hexTile
;%TYPE=MODEL
63.4349488229,0,0,5.366563146,-1.788854382,4.4721,-13.41644382
0,2,4,4,4,2,-6
-63.4349488229,4,4,5.366563146,1.788854382,4.4721,-13.41644382
Has anyone got a .pat file for the regular honeycomb pattern ? I've been trying to find it for the past 30 minutes but no luck. I don't understand why it's not implemented in Revit in the first place.
I've tried adding the acad.pat file and other honeycomb.pat files from RevitCity but I ALWAYS get this error message : "IMPOSSIBLE TO FIND PATTERN TYPE MODEL"
Please help me thanks.
EDIT : For future reference, this is the text in the pat file that doesn't work :
;%UNITS=MM
;%VERSION=3.0
0, 0, 0, 1.875, 1.0825317547305483084546539634412, 1.25, -2.5
120, 0, 0, 1.875, 1.0825317547305483084546539634412, 1.25, -2.5
60, 0, 0, 1.875, 1.0825317547305483084546539634412, -2.5, 1.25
And the pat files that are found in the solution work for Revit 2019 but I don't want that specific pat file I'm searching for the regular hexagon pattern.
try this, what you need to make the pattern recognised as a MODEL pattern is the highlighted line immediately following the pattern name:
; Written by HatchKit Team Edition
; HatchKit Team Edition (c)1990-2019 Cadro Pty Ltd
;-Date : 2019-03-25
;-Time : 17:29:00
;-HatchKit Team Edition Version : 3.1.11.2776
;-HatchKit Team Edition Output Filetype : Revit with HatchKit Add-In
;%VERSION=3.0
;%UNITS=INCH
*HONEY,Honeycomb pattern
;%TYPE=MODEL
-60,-0.0625,0.10825,0.1875,0.10825,0.125,-0.25
60,0.125,0.21651,0.1875,0.10825,0.125,-0.25
0,0,0,0.1875,-0.10825,0.125,-0.25
hope this helps,
Hugh Adamson
Try this:
; Written by HatchKit 4 Standard Edition
; HatchKit 4 Standard Edition (c)1990-2021 Cadro Pty Ltd
;-Date : 2021-04-16
;-Time : 02:25:49
;-HatchKit 4 Version : 4.1.1.2998
;-HatchKit 4 Output Filetype : Revit with HatchKit Add-In
;%VERSION=3.0
;%UNITS=INCH
*FlatHex,
;%TYPE=MODEL
0,1.6667,1.6667,8.33333333,1.66666667,6.6667,-10
0,1.6667,-1.6667,8.33333333,1.66666667,6.6667,-10
45,0,0,-9.42809041,2.35702260,2.357,-9.42809041
45,8.3333,-1.6667,-9.42809041,2.35702260,2.357,-9.42809041
135,10,0,-2.35702260,2.35702260,2.357,-9.42809041
135,1.6667,-1.6667,-2.35702260,2.35702260,2.357,-9.42809041
hth,
Hugh Adamson
Or this:
;-Date : 2021-04-16
;-Time : 02:25:49
;%VERSION=3.0
;%UNITS=INCH
*FlatHex,
;%TYPE=MODEL
which by eliminating elements that overlay halves the pattern "weight".
This result cannot be obtained by generators requiring a rectangular arrangement of the pattern template.
hth,
Hugh Adamson
anyone have a Hexagon pattern the is DASHED.
Trying to use this pattern for demolition.
-Thanks Val
