Parts of wall disappear in 3D when shadows added
11 ANTWORTEN 11
Nachricht 1 von 12
stephen.melhuish
547 Aufrufe, 11 Antworten
I have a Revit model that has a thin cement wall added over the top of an existing brick wall. The existing brick wall is in the Existing Phase and the Render is in the New Construction Phase.
When i view the model in Perspective it is ok UNTIL I turn on the Sun (Graphic Display Options: Lighting), when the new Construction Phase cement layer partially disappears. Any thoughts ?
11 ANTWORTEN 11
Nachricht 2 von 12
als Antwort auf: stephen.melhuish
What's the View Phase Filter set to?
Is the issue replicable? Create another like View and see.
Nachricht 3 von 12
Strange, I take a different 3D view, this time of the rear and get a different result for 2 different locations of the same elevation (see attached)
Nachricht 4 von 12
Nachricht 5 von 12
Are you using sketchy lines?
Try disabling Hardware Acceleration.
Help: Hardware Acceleration (autodesk.com)
Nachricht 6 von 12
stephen.melhuish
als Antwort auf: barthbradley
Unfortunately still no luck I'm afraid. I disabled hardware acceleration and re-started revit but still got the same problem. I'll re-do the perspective views and see if that will resolve matters
Nachricht 7 von 12
How thin is the plaster wall?
Nachricht 8 von 12
stephen.melhuish
als Antwort auf: ToanDN
The cement render is just 20mm thick. However, the same is also occuring with timber cladding which is 20mm thick with 25mm air behind
Nachricht 9 von 12
BIM-CONG
It seems like that the two "walls" including brick and cement ara overlapped.
CONG XU
您认为此帖子是否有用?欢迎为此帖点赞。
您的问题是否已得到解答?请点击“接受解答”按钮。
- BIM THE FUTURE -
Nachricht 10 von 12
stephen.melhuish
als Antwort auf: BIM-CONG
They don't overlap but I have found that if I move the New Construction wall I placed over the Existing wall away from the Existing wall then it seems to work.
Nachricht 11 von 12
syman2000
Do you have any CAD link or heavy 3d family inside the project?
Nachricht 12 von 12
BIM-CONG
Emmm it's a little strange, can you post a partial model with this issue?
CONG XU
您认为此帖子是否有用?欢迎为此帖点赞。
- BIM THE FUTURE -
