Parts of nwd dissapears when rotating in 3D
5 ANTWORTEN 5
Nachricht 1 von 6
Gilles.Lagrilliere
385 Aufrufe, 5 Antworten
Hi everyone,
Parts of the nwd dissapears when I'm rotation (see video).
does anyone know how this is happening? or have a solution?
Thanks!
Beschriftungen (2)
5 ANTWORTEN 5
Nachricht 2 von 6
als Antwort auf: Gilles.Lagrilliere
Could be Revit Simplifying Display.
Could be corrected by unchecking Hardware Acceleration (in same dialog box) - which would point to a possible Graphics Card issue.
Could be far-away elements causing.
Nachricht 3 von 6
Model geometry must be positioned within a 16 kilometer (10 mile) radius from the internal origin. Exceeding this distance may reduce reliability and result in undesirable graphic behavior
All geometry in a Revit model should be within 10 miles or 16 kilometers of the model's internal origin.
This limitation applies to geometry created in Revit as well as incoming geometry from an import or a link.
When you create a Revit model, you are working on a modeling work plane that is 20 miles or 32 kilometers in diameter, with a radius of 10 miles or 16 kilometers from the internal origin. All geometry for the model, including geometry from an import or a link, should reside within the limits of the modeling work plane.
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | Especialista BIM
aAutodesk Certified Professional
Nachricht 4 von 6
azad.Nanva
I saw this before as the graphic problem. Walls, windows or small things disappeared but they are still there, just it is graphic issue.
if this happens too much, you should upgrade your hardware.
Nachricht 5 von 6
handjonathan
Hi @Gilles.Lagrilliere
Thanks a lot for posting your question to the forums!   Have the solutions suggested by @barthbradley @vitorbortoncello @azad.Nanva helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
Nachricht 6 von 6
Gilles.Lagrilliere
als Antwort auf: handjonathan
none of the solutions have worked. and the solution of azad.Nanva is something I cant test cause its a company pc I have. If I can upgrade the hardware it would take a long time when thats gonna happen.
