Parts of Camera Image blurry
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
J_Lewis87
464 Aufrufe, 4 Antworten
I was able to create a camera view looking up through a circular staircase. The vertical surfaces are clear including the stair balustrades.  However, the planes parallel to the floor are blurry.
Does anyone know what might be going on and how to fix the issue?Stair_tower_looking up.jpg
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: J_Lewis87
Try Increase/Decrease Focal Length of Camera.
Nachricht 3 von 5
J_Lewis87
als Antwort auf: barthbradley
No bueno.
I zoomed in and zoomed out.  I've attached the latter. Oddly the underside of the stairs is the most blurry.Stair_tower_looking up_focal_length.jpg
Nachricht 4 von 5
mauricio_mssf
I don't think it's out of focus, it seems that the problem is in the stair material, the texture is very small or of low quality, so it looks blurry.
Try to change the material or the texture image.
If the answer solves your problem, click Accept as Solution this helps other users to quickly find an answer and let a like if you liked it.
Você achou esta postagem útil? Sinta-se à vontade para curtir esta postagem.
Ficou satisfeito com a resposta à sua pergunta? Nesse caso, clique no botão ACEITAR SOLUÇÃO.
 Mauricio Santos Filho Arquiteto | BIM Manager
Nachricht 5 von 5
J_Lewis87
als Antwort auf: mauricio_mssf
Thanks, that corrected the issue. I had forgotten to assign the treads a material. So I assigned one and the blurriness abated:
