Hi!
I'm using the function parts in revit, to calculate amounts of different types of walls.
I've saved a copy of my model, and used the function create parts for the walls. When I do this, there's a wall with base in ground floor and top in 5th floor, which disappears from 1st to 5th floor. It's still there on the ground floor, see pictures.
I have a copy of the model from before I joined the walls and the floor, and at this point the whole wall is still there. See picture.
Anyone who can help me with this problem?
Try to check the Parts Visibility in the properties..
Thank you, but it's visible. All the other walls showing is parts as well.
When I'm in a section and select "Show Parts" the wall disappear.
I'm not sure how you change the phasing. But I've made a copy of the original model, selected all the walls and "create parts". I've done this at least 5 times now, but this one wall disappears every time - after I joined the walls and the floor.
@Anonymous ,
Do you have accidentally check the excluded ?
Nope, the box is unchecked. Well, I don't see the wall, so it's not possible to check if it's checked or not. But the wall does not behave as it would if it was excluded. It's just gone.
I think I'll just go back to the earlier model, from before I joined wall and floor. In this model all the walls are there. So I'm pretty sure something happens when joining. I've tried to unjoin and join again multiple times, with no luck - the wall is still gone.
Thank you!
I've gone through these steps now. Since parts of the wall is there (on the ground floor), many of these steps are irrelevant. It's gone in all the views when I select "show parts", but the whole wall is there when I select "show original".
