Hi there!
I created parts on the wall imitating the rusticating. When I delete the partless wall that touches the one with parts Revit gets moody and says:
"Wall part could not be properly adjusted for join condition. Geometry may be inaccurate." and I can either stop the action or "Delete parts for this wall".
I unjoined any geometry the unwanted wall had. Revit keeps this blocade even when I only change the base/top constraint for that wall.
Do you have any clue what might be goin wrong?
I keep having this problem quite often and usually just agree to what Revit says, but this time too much effort has been put to simply erase it and start over.
Thanks!
Try to select the wall which generated the parts, the parts and then cut to clipboard. Delete the "partless" wall and then paste aligned to same place. See if that helps?
Andrej Ilić
phonetical: ændreɪ ilich
MSc Arch
Autodesk Expert Elite Alumni
