Part of the Grid is completely missing
Hallo everybody,
I ask for your help regarding the Grid that partly disappeared.
1. Only part of the Grid disappeared. The Horizontal grid is still there, only Vertical grid has gone. So it can not be Visibility overrides
2. The horizontal Grid is missing everywhere (All plans, sections, elevations).
3. There is no scope box applied in the Project
4. The Grid is not hidden, that I checked the first
5. I would think, that the grid was coincidentally deleted, but when I try to create grid using the same names (A, B, C, D) it says that I can not, because these names are already in use and I should use Unique names...
Please Help me!
Sincerely Iryna
It's possible that the grids are not in the range of the view.  First select a grid line that you can see and type SA (select all).  Check the count at the bottom right to see that there are the expected amount of grids.  If that looks right, go to a plan view, do not crop the view and zoom to extents.   If it is still not visible, adjust your view range to unlimited.  While you doing this also check the 'Reveal Hidden elements' - the grid could be hidden in more that one way, so even if you have checked it before, check again after each step.  If its still not visible, check if there is a filter applied to the category in the view.  Next check that it's not on a hidden workset.  It's more than likely one of those.
Select on grid, right click and Select All in Project, another right click and Maximize 3D Extent.
Dear
dear TimELZ49
Thank you very much for the very extended answer!
Have a nice day.
P.s.I will have a nice day for sure, because I have my grid back!
