I am trying to merge to parts together (see attached). However when clicking merge parts, I get the message ''Part cannot be merged with others.'' The parts do overlap but this shouldn't be a problem according to the Autodesk website.
It also tells me that the material should be the same for both parts and that creation and demolition phases should match. I checked this and they match.
What could be the problem here?
Thanks in advance.
It could be sliver edges. This happens when the overlap betwwen parts is minimal at some areas, then Revit has difficulty to claculate the merged areas.
Test this out with simpler merging parts (e.g two boxes) and see if it works then
Louis
Please mention Revit version, especially when uploading Revit files.
