Parking component on warped slab
3 ANTWORTEN 3
Nachricht 1 von 4
josh.hafel
351 Aufrufe, 3 Antworten
I am wondering if anybody has had this issue and/or come up with a solution to this issue. I am trying to use a parking component on a slab that is being warped with 'modify sub elements' too to meet different FFEs Because of this, the parking spaces are not displaying accurately in the plan because they are going into the slab. Any advice?
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: josh.hafel
Is the Parking Space straddling different faces going different directions?
Parking Space hosts to only one surface.
Nachricht 3 von 4
josh.hafel
als Antwort auf: barthbradley
Yes, I tried to make using symbolic lines and hide the 3d in plan views, but that did not do anything, I am assuming that it is because the parking stripes are following the face and they are not parallel to the plan view. Someone within my firm suggested using an adaptive component, but I have no experience making adaptive components so I wanted to get a second opinion on the forums
Nachricht 4 von 4
Try doing your striping using a Rail Family. A Rail will follow changes in direction of surface it's hosted to.
