Parapet on a ramp
2 ANTWORTEN 2
Nachricht 1 von 3
NERDASORUS
379 Aufrufe, 2 Antworten
Parapet on a ramp
hello
i have a ramp that i want to add a parapet along the green lines, that is 1m above the ramp surface.
I have tried:
1- slab edge: cannot select the edges i want, i can pick the other two though
2- model in place: the sweep would do the trick, but need to find another way
3- Wall edit profile: cannot edit the wall profile (maybe because its curved)
is there any other way??
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: NERDASORUS
There are many ways to model them.  An easy one is to create two railings with a solid rail profile, or two other ramps, narrow and 1 meter tall.  If they must be walls, you can model in place as swept blends, or walls by mass faces.
Below is the easy way out using railing.
Nachricht 3 von 3
WEC17
You can model a wall cut a section along the wall and change the profile of the wall to follow the ramp slope.
