PARAMETRIC WINDOW HELP
emmacain
emmacain
I am trying to create a window as per image attached.
The height, width & transom parameters for the frame are good - but I'm having trouble with the two inside vertical frames (circled in image).
When I increase the width of the window, the two inner frames aren't flexing or moving with the frame - they're staying the same size.
Can someone please tell me what I'm missing here? This is my first attempt at parametric windows.
Thanks so much!
Em.
UPDATE - I can make one side flex but not the other!? I've done the same thing on both sides when creating window, so don't know why this is happening? See image attached.
RDAOU
@emmacain
To make it parametric, you need to use parameters that control both the width of the panels (side vs. middle) and the height (lower vs. upper).
See the GIF example below and the attached Revit 2022 family demonstrating this.
