Parametric TitleBlock
1 ANTWORT 1
GELÖST
Nachricht 1 von 2
dm0144
294 Aufrufe, 1 Antwort
Hello everyone
I have an issue aligning the short vertical lines, which indicate the place where the paper has to be folded, to the margins of the paper. The vertical marks are grouped and have group array parameter depending on the width of the paper.
Please help:gefaltete_Hände:
Thanks!
1 ANTWORT 1
Nachricht 2 von 2
RDAOU
als Antwort auf: dm0144
@dm0144
Array or Floating lines can be very unpredictable...If you want to stick with that, I would suggest the following
  1. do not group the top lines with the bottom ones.
  2. For the sheet height (Vertical), the inner frame/border and the Folder lines
    • use 2 horizontal reference line at the top and 2 at the bottom
    • All constraints/parameters should reference these lines
    • lock the Horizontal lines to these Reference lines
  3. Array the top and the bottom folder line separately.
    • Both will use the same array parameter but in 2 different arrays
    • Make sure to lock the top/start and bottom/end of the folder-lines to these reference lines too
    • PS: the use of reference line and locking Detail lines to them will help you avoid the Error Promt "Sketch is Over constrained"
Attached is a Revit 2022 Version, maybe you can open it and see how it is constructed. I do not have 2021
FWIIW: Personally I neither like nor recommend the all-in-one Title Blocks. It is more practical to create a different title block family for different paper space
