Parametric Text Annotation
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
skyeg321
881 Aufrufe, 4 Antworten
Hey all. I want to make text notes that are savable and editable so I don't have to copy/paste these notes across multiple views. I've included 2 pics to illustrate the point. I basically have basic text notes such as the note for the roofing callout and there is one per elevation. If a change needs to happen to that note then I need to edit that note in all elevations. I would like to change the note in one location and have it update across all views. Is this possible? Ideally there would be a central location where all these notes are stored then when they are changed there they change in all the views.
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: skyeg321
Keynotes? or make the notes a Group?
Nachricht 3 von 5
Corsten.Au
Hi
Master the skill of keynoting..
1. Element  keynote
2. Material keynote
3. User keynote
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2016/EN...
Corsten
Building Designer
Nachricht 4 von 5
skyeg321
als Antwort auf: ToanDN
Keynotes! I ended up making a material keynote file then applying those keynotes to the materials in the project. I'll look into user keynotes, those sound promising. Thanks!
Nachricht 5 von 5
Corsten.Au
Hi @skyeg321 Pls Mark @ToanDNToan for accepted solution as well...
Corsten
Building Designer
