Hi Guys!
I need to make a parametris family. Its a round circle pot, and i want to move all togheter with just one parameter of radial.
Anyone know hoy to do this?
Sorry for bad english
Gelöst! Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
Are you wanting to model a parametric pot like this? Or are you just talking about a parametric 2D plan symbol?
Are you referring to those round planter walls. You can use thick walls for those. They look to be about 18-inches high.
Yes like that!
But i want to make a family to change de diameter as i need to be bigger or smaller
It really quite simple. It's an Extrusion. Inspect the attached family to see how it is done.
and i need to know for example, i want to change de inside radius and i want the outside radius change togheter.
@Anonymous : You marked the wrong post as the Accepted Solution. Mark one of my posts as the Accepted Solution and delete the one you gave to yourself.
See attached 2019 RFA -- done especially for you.
How can i do to change inside radius and mantain proportion on outside radius?
You can get there with a Formula the adjusts the Inside Diameter based on the width/thickness of the planter.
