Parametric rotation
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
Szigeti.Eduard
451 Aufrufe, 2 Antworten
Parametric rotation
I'm trying to parametricaly rotate a ridge a roof but when I try to add the reference line in the familly editor it just seems that there are more instances of the ridge in one place.
I need to rotate this left/right and back/front.
2 ANTWORTEN 2
Nachricht 2 von 3
Alfredo_Medina
als Antwort auf: Szigeti.Eduard
In Category & Parameters, set this family to be workplane based, and not always vertical. Maybe remove that box on the left, and move the actual geometry to the center. Then, in another family, draw a diagonal reference line in plan view and constrain it to an intersection of reference planes. Constrain the rotation of that line with an angular parameter. Then load this family into the new family, hosting the geometry on the reference line. If you want a rotation in a different plane, repeat the process in another, third family, carrying on the rotation parameter from the second family to the third.
Nachricht 3 von 3
Szigeti.Eduard
als Antwort auf: Alfredo_Medina
Thank you
