Is it possible to make my Revision Schedule get longer as my titleblock gets taller?
In our CAD titleblocks, we eat up some of the extra space in the titleblock with extra lines in the revision schedule, but they're just lines.
I have my Revision Schedule as user defined so I can stretch it to the size I want, but can't figure out a way to lock it to something in the titleblock to make it stretch on it's own.
I'm trying to avoid the inevitable "this doesn't exactly match the CAD version" conversation.
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Create different titleblock families and different revision schedules to match.
If you set the height of the revision schedule to variable instead of user define, this will keep your schedule expand as you add more revision. This works well if you have parametric titleblock and expand the revision schedule. However it will display as blank unless you add those revision.
This means you have to add array lines as you expand and turn off schedule lines.
There are no benefits to have a titleblock family with different sizes. You just provided another reason to add to the list.
